DIODE RESISTANCE-Urgent
Discussion in 'The Projects Forum' started by yellowstone, Dec 16, 2008.
  1. yellowstone
    Dec 16, 2008
    Is there a calculator available for determining the series resistance of the diode.(ie RS which is given in the data sheets)
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    A diode can not be expressed in resistance.
    It conducts current one way (so a low resistance) if the voltage is over the Forward voltage.
    It isolates in the counter direction (very high resistance).
    Here is a page of the EDUCYPEDIA with a lot of links to information on DIODES.
    http://www.educypedia.be/electronics/composemiconductorspassif.htm
    Greetings,
    Bertus
  3. mik3
    Feb 4, 2008
    4,846
    63
    If you are talking about the bulk resistance, you can calculate it if you measure the current through the diode and voltage across it. The voltage across the diode will be the sum of the junction voltage and the voltage across the bulk resistance. If you subtract the junction voltage (from the datasheet for a given current) from the voltage across the diode you will get the voltage across the bulk resistance. Then divide the voltage across the bulk resistance by the current through the diode to get the value if the bulk resistance.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    Can you link to a datasheet we can look at? Not all diodes spec Rs.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The parameter would be Rs - R sub s, or resistance depending on whatever s stands for - if such an animal can be found.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    S stands for series, as the OP said in his first post.:D
  7. steveb
    Jul 3, 2008
    2,433
    469
    This specification seems to be more relevant for switching diodes. I attached a PDF for a switching diode that specifies the forward resistance.
    Also, I've attached a paper that discusses a more complex diode model which includes series resistance and capacitive effects.
  8. Ron H
    Apr 14, 2005
    7,050
    657
    The BA483 spec is for Rd. Rs appears to be another animal.
  9. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Rs appears to be a bulk semiconductor resistivity.
  10. steveb
    Jul 3, 2008
    2,433
    469
    The nomenclature can be confusing. It's difficult to be sure if everyone conforms to one standard that Rs is the bulk resistance and Rd the diode resistance. So far we see the following.
    1. The BA846 data sheet says Rd is the forward resistance, which would seem to imply that bulk resistance is included. Granted it may be negligible, but still confusing.
    2. The modeling paper I referenced uses Rs for the bulk resistance and Ri for the diode resistance.
    3. Ron H. shows a reference with Rs the bulk resistance and Rd the diode resistance.
    4. The OP is looking for the series resistance RS
    It's difficult to be sure which spec the OP is looking to calculate, but hopefully he can figure it out from what is available. The paper I referenced gives a formula for the bulk resistance (Rs in that paper), but this depends on design parameters that may be unknown. The diode resistance is well known and the formula is commonly available and depends on current and temperature.
  11. yellowstone
    Dec 16, 2008
    i am trying to find the total resistance of the diode ( ie resistance of a p type diode+ contact resistance.)
