Diode Recommendation
Discussion in 'General Electronics Chat' started by crazyengineer, Jun 8, 2011.
Thread Status:
Not open for further replies.
  1. crazyengineer
    Dec 29, 2010
    156
    Hello Everyone,
    I'm getting ready to do my first high voltage electricity experiment. All I want to do is get the voltage from a household wall outlet (I'm assuming 120v, current I don't know), feed the voltage to a strandard full wave rectification circuit and get a high dc voltage from it. The problem is I have no idea what type of diodes I should get. Does anyone have any recommendations?
  2. tom66
    May 9, 2009
    2,613
    214
    What is the maximum voltage the diodes need to withstand?
    For mains applications 1N4005 - 1N4007 are suitable, with PIV's ranging from 600V to 1000V. 1N4004 is okay for 115V mains, but pushing it for 230V, as that is 325Vpk and 1N4001's are only rated to 400V.
  3. magnet18
    Dec 22, 2010
    1,232
    125
    Just go with 1n4007, they can handle just about anything.
    If you need faster switching, go with uf4007, high voltage and ultra fast recovery, and they're a dime a dozen.
    Also, mains rectification is not allowed on here according to the TOS, so this will probably be closed shortly.
  4. soundman
    Dec 27, 2010
    13
    I think there is a restriction on questions concerning transformerless power supplies so your question may disappear on you. Look at the posting in this section by "Been There" regarding automotive modifications.
  5. crazyengineer
    Dec 29, 2010
    156
    opps! Sorry :(
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Amateurs/hobbyists should not experiment with direct mains power, as the likelihood of being the guest of honor at a funeral is quite high.
    Always use an isolation transformer that is protected by a fuse, as that will limit the hazard at least somewhat.
    With high voltage, even a few milliamperes through the torso can cause fatalities.
    If you keep your experiments below 50v, your likelihood of survival increases dramatically.
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It's the Terms of Service that won't let us discuss this - it's just too dangerous.
Thread Status:
