diode read/replace equivalent
Discussion in 'The Projects Forum' started by billybobb, Jan 14, 2012.
  1. billybobb
    Jan 14, 2012
    I'm really ignorant about diodes. I found 1 on my John deere tractor. It has no continuity in either direction. I believe it's bad. How do I identify it so that i can purchase an equivalent? thanx.
  2. Adjuster
    Dec 26, 2010
    2,147
    300
    You could start by posting a picture of it, and even if you can't do that right away, a description would help: what does it look like, how big is it?
    Mention of any codes marked on it would be a start. You might even find that you could find out about the device by putting them in a web search.
    Of course, you would do well to make sure that this is a diode - what was it doing on the tractor?
  3. billybobb
    Jan 14, 2012
    It's about 1/8" long cylindrical like a resistor with silver band over 43 over 004. It was encased in silicone which I split/cut and in process may have scratched off markings. I'm trying to learn what it does; haven't yet followed the wiring; was hoping someone had been here before and would know about john deere which tries to keep their wiring diagrams secret. JD calls it a diode in their parts listing. I want to understand what I'm doing rather than just replace a part. Thanx again
  4. jimkeith
    Oct 26, 2011
    539
    99
    Could it be 1N4004? Often the 2nd line is "004"
    Very, very common diode--used everywhere
    General purpose
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
