Diode questions
Discussion in 'Homework Help' started by whitewar1004, Dec 9, 2006.
  1. whitewar1004
    Dec 3, 2006
    I don't understand the first graph...because if V1 ever becomes positive, there won't be any current in V0(diode)??
    but in the graph V0 keeps getting larger as v1 increases to some positive voltage..
    Can someone please explain to me what i'm missing in this graph???
  2. beck
    Member
    Nov 27, 2006
    26
    When the voltage across the diode is +ve, the diode is off.
    this means that whatever voltage is applied in the input side
    is seen in the output.
    so vin=vout
    Remember that when the diode is off it acts like an open circuit.
    in your case replace the diode with an open circuit and you will
    get that same graph.
