Diode Problem
Discussion in 'Homework Help' started by MatthewPerry, Feb 20, 2011.
  1. MatthewPerry
    Nov 29, 2010
    Hi. I've been trying to understand the solution to a practice problem in my book (it only provides the answer), but I cant seem get it. The problem gives the circuit in the attachment and asks the following: Find a value of R such that V0 is equal to 2.4 V. Assume that the diodes available have 0.7 V drop at 1 mA.
    The solution is R = 139 ohms. I keep getting about 160. If someone could tell me how I should go about solving this it would be great! Thanks.
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    You forgot to attach the diagram.
  3. MatthewPerry
    Nov 29, 2010
    Here it is.
  4. Jony130
    Feb 17, 2009
    3,993
    1,116
    Te get the right answer you need to use Shockley diode equation
     Id = Is * e^{\frac{Vd}{26mV}}
    First you need to find Is current, because you know Id = 1mA; Vd= 0.7V so
    Is = 2.03fA
    Now you want Vo = 2.4V but you have three diodes so Vd = 2.4V/3 = 0.8V
    Id = 2.03fA * e^(0.8V/26mV) = 46.816mA
    So we know Id current which causes 0.8V voltage drop across the diode.
    And now we can find resistor R.
    R = (10V - 2.4V) / 46.816mA = 162Ω
    So I get the same answer as you.
    MatthewPerry likes this.
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
    I support Jony130's method of solution.
