Hello, to make this short, i had remote start for my car till one day when i shut it off and it shorted out i guess and all it wants to do when its hooked up is turn my starter over.. Ive gone through just about everything and there are two diodes, one a zener and one a 1n4007 diode. Before i un-sodered the 4007, i tested it and it had .162 each way and 0 resistance both ways. Thought that was my problem so i took it off and now it shows OL for reverse bias, which is good. I put a new 4007 in its place anyway, and now that one shows 0 resistance each way.. Im so lost. Are they good then? They do it without the main chip in too.. Only tries to start the car when i hook the 12V to the remote start module
Anything will help!
Thank you!
TheKidInBuff
Anything will help!
Thank you!
TheKidInBuff
