Diode Help!!! (Kb-162)
Discussion in 'General Electronics Chat' started by bonsaimaster1, Dec 7, 2015.
  1. bonsaimaster1
    Feb 8, 2013
    10
    hello, I am currently having a problem finding this diode for sale around here. It is a Kb-162 varistor diode from japan. I am sure it is old and outdated, but I either need to find this part, or find a part that replaces this one. Any help would be great. The pictures I am sending is the part I am looking for. varistor diode.jpg varistor diode 2.jpg
  2. crutschow
    Mar 14, 2008
    13,505
    3,382
    Do you have any info on it's operating characteristics?
    Where is it used?
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Does this say you anything?
    Bertus
  4. ian field
    Distinguished Member
    Oct 27, 2012
    4,459
    792
    Found this quite easily with Google:
    http://www.datasheetarchive.com/dlmain/Databooks-5/Document290-6534.pdf
    The built in pdf viewer in W10 isn't much good, so I didn't inspect the document closely.
  5. bonsaimaster1
    Feb 8, 2013
    10
    Thanks Ian. Just wish I could find these components though.
  6. SLK001
    Nov 29, 2011
    852
    243
    Hell, even a simple search found this(NTE601 ECG601 SK3463 GE-601 M8513 Si Varistor Temperature Compensating Diode NEW)on fleaBay.
  7. bonsaimaster1
    Feb 8, 2013
    10
    Thanks for your sarcasm SLK001, I saw that as well, but I am mainly searching for these exact diodes. Thanks for the rude comment, I'll remember how you are from now on!
  8. ian field
    Oct 27, 2012
    4,459
    792
    What will you do if *THAT* part is discontinued?
    Its not an abundant part - but not completely rare either - Philips do a range of temperature compensating bias diodes - as I'm sure several other makes do.
    You could end up with no alternative to reading the data and selecting an equivalent part.
  9. bonsaimaster1
    Feb 8, 2013
    10
    True, well I guess if I can't get my hands on any. I'll just have to find an alternative such as the part SLK001 listed.
