diode equation
Discussion in 'Homework Help' started by God1600, Oct 13, 2008.
  1. God1600
    Oct 13, 2008
    Hi All
    please help me out with the following problem.
    Temperature of the p-n junction is 300k,saturation current to be 5.0nA and emisssion coefficient to be 1,Calculate the ratio of the current through the diode for a 0.5v forward bias to the current for a 0.5v reverse bias.What is your comment on this ratio.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
  3. mik3
    Feb 4, 2008
    4,846
    63
    I=Is*(e^(Vd/k*VT)-1)
    where
    I=diode through diode
    Is=reverse saturation current
    Vd=voltage across diode (actually across the junction)
    k=emission coefficient (constant which depends upon the construction of the diode)
    VT=thermal voltage =KT/q which at 300K approximately equals 25mV
    For Vd=0.5V
    I=(0.5*10^-9)*(e^(0.5/1*0.025)-1)=0.243A=243mA
    for Vd=-0.5
    I=(0.5*10^-9)*(e^(-0.5/1*0.025)-1)=-4.99*10^-10=-0.49nA
