Diode difference
Discussion in 'General Electronics Chat' started by blackredrobin, Sep 23, 2011.
  1. blackredrobin
    Sep 14, 2011
    9
    :)what is the difference between Diode
    UFXXXX & 1NXXXX (for instance UF4004 & 1N4004...)
  2. colinb
    Jun 15, 2011
    351
    35
    blackredrobin likes this.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Keep in mind that silicon rectifier diodes like the 1N4001 thru 1N4007 and 1N5401 thru 1N5407 are very different from Schottky barrier diodes like 1N5817 thru 1N5819; the Schottky diodes have extremely low recovery times.
    Standard silicon rectifier diodes work OK for rectification of sine waves up to around 500Hz or so, but beyond that you should be using faster diodes.
    Here's a table I excerpted out of a news article from Rohm:
    #12 likes this.
