Hello again
I need sugestions for the following schematic, the diodes D1..D4, when the DC voltage applyed is inverted the circuit shorts, another use is place-it in series and it will only leak some current when polarity is inverted.
I placed in parallel because if user does not connect it properly it will have a nasty surprise, and the idea is that he will imidiatly notice, please recommend this or other method.
Calculations of the values are not done yet so please ignore the componentes value.
The input voltage at J3 and J4 will be a switching power suppy with short circuit protection, and I will add a fast fuse to the design.
