find the voltage across each diode. assume practical model.
please help me get started.
I would go with 5-8=-3 volts.In the diagram on the left. I can say that the diode is reverse bias because the cathode is connected to a higher potential 8v. now if it is reverse biased it is like an open switch. The voltage across it would be the sum of the batteries.
but I don't understand what to use 8-v =3v or 5-8=-3v?
You said it yourself, the anode of the diode is at lower potential than the cathode of the diode.but why is that? why it is not the other way?
Usually, but not always. The most common situation in which you see the other convention used is with Zener diodes.Is it always the case that when we say "voltage across a diode" means voltage at the anode relative to the cathode?
Yes. Same with resistor.Is it always the case that when we say "voltage across a diode" means voltage at the anode relative to the cathode?
????Yes. Same with resistor.
I was referring to the voltage drop. Anode and cathode refer to the internal structure of the diode.????
I didn't know that a resistor had an anode and a cathode? How do you tell which end is which?
by Jake Hertz
by Aaron Carman
by Aaron Carman
by Duane Benson
