diode circuit waveform
Discussion in 'Homework Help' started by ADCapacitor, Feb 19, 2016.
  1. ADCapacitor
    Feb 3, 2016
    42
    What is difference between half-wave and full-wave rectifier ?
    Half-wave only show the positive part of the sine wave?
    After I add a capacitor in parallel to the diode circuit, why I get this result(figure)?
    Thank you
  2. Kermit2
    Feb 5, 2010
    3,837
    961
    Full wave uses the positive and negative portion of the AC input. Half wave only uses one portion of the AC input and blocks the other half.
  3. crutschow
    Mar 14, 2008
    13,462
    3,353
    The capacitor charges to the peak voltage (minus the diode forward drop) and retains the charge when the diode stops conducting.
    During the time the diode is not conducting, the capacitor provides current to the load, causing the observed droop in the voltage as the capacitor discharges.
    The amount of the droop is determined by the capacitor size and the load current.
