Diode circuit design problem
Discussion in 'Homework Help' started by Alice, Mar 23, 2009.
  1. Alice
    Mar 29, 2008
    I need help on the following problem:
    I can't attach an image of the circuit, but it's pretty straight-forward. There's a 15 V dc source in series with a resistor R of unknown resistance, and in series with a string of four forward biased diodes going to ground. The circuit output Vo is across the string of 4 diodes.
    Design the circuit so that Vo = 3V when IL = 0 (the load current is zero) and Vo changes by 40mV per 1mA of load current.
    I need to find the value of the resistance R and the junction area of each diode relative to a diode with a 0.7 V drop at 1mA. n = 1.
    I've tried several different methods and nothing is producing the correct answer. (the solution is provided, R = 4.8KΩ and junction area = 0.34)
    I'm not sure if using the small-signal diode model is justified in this case since it seems that the change in voltage per 1 mA per diode is too great. However when I try using the exponential model, using the equation v2-v1 = 2.3nVTln(I2/I1) and a KVL equation to solve for the resistance R, I don't get the right answer either.
    Any help would be greatly appreciated!... and I really do need this by tomorrow:/
    Thank you,
  2. Ron H
    Apr 14, 2005
    No they aren't.:rolleyes:
  3. Alice
    Mar 29, 2008
    yeah... hence the recent editing of the post:) sorry 'bout that
