Diode at Op Amp Output
Discussion in 'General Electronics Chat' started by jwilk13, Aug 6, 2012.
  1. jwilk13
    Jun 15, 2011
    228
    12
    I recently came across a simple schematic that I had a question about, so I thought I'd post it here. It's a simple non-inverting amplifier configuration, but with a Schottky diode at the output inside the feedback loop. The only thing I can think of is that it's used to protect the op-amp's output or possibly drop the voltage to a specific value. But if it were simply there to protect the output, couldn't it be placed outside the feedback loop?
    Any thoughts?
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    What happens if the 'DC in' signal is negative?
    jwilk13 likes this.
  3. #12
    Nov 30, 2010
    16,694
    7,334
    The diode is inside the loop so that the output voltage after the diode's voltage drop is proper for the equasion for gain: Vo = Vin x (1+ (R2/R1)) You could imagine the diode to be inside the op-amp with exactly the same result.
    The diode forces a lack of negative voltage output from the amplifer, no matter what the input is, but it does not interfere with the gain equasion.
    jwilk13 likes this.
  4. BillB3857
    Feb 28, 2009
    2,402
    348
  5. jwilk13
    Jun 15, 2011
    228
    12
    Both very interesting!
    How about if the supply rails for the op-amp are +Vs and ground? The op-amp wouldn't be able to output a negative voltage anyways, correct?
    As far as not interfering with the gain, that makes total sense. If you change the connection and put the diode outside the feedback, the output voltage drops due to the drop of the diode.
  6. #12
    Nov 30, 2010
    16,694
    7,334
    If you're going to go messing with the power rail voltages you're going to have to give me a drawing. (My imagination level is only about a 6 today.)
    Let's change to the word, "current". No matter how you mess with the supply voltages, no electrons will come out of the op-amp and go through the diode.
  7. jwilk13
    Jun 15, 2011
    228
    12
    I was just thinking out loud (at least about as loud as my typing is). This makes sense.
    And Bill, question 5 isn't similar to what I'm talking about. Maybe I'm missing something?
  8. #12
    Nov 30, 2010
    16,694
    7,334
    It went over my head, too.
  9. MrChips
    Oct 2, 2009
    12,635
    3,454
    Half-wave rectifier.
    #12 likes this.
  10. crutschow
    Mar 14, 2008
    13,498
    3,374
  11. WBahn
    Mar 31, 2012
    18,087
    4,917
    Is it?
    When the input is negative, the output is resistively tied to ground. That's not what I usually think of when I think of a half-wave rectifier. But it's certainly close.
  12. crutschow
    Mar 14, 2008
    13,498
    3,374
    You left us hanging. ;) So what do you think of when you think of a half-wave rectifier? For a negative input, the output is zero volts, which is what a half-wave rectifier would provide. Where would you tie the output for a negative input voltage if not ground?
    Understand this is for signal rectification only, not for power rectification.
