Diode as a SPST switch not a rectifier
Discussion in 'General Electronics Chat' started by watsongrey, Nov 3, 2014.
  1. watsongrey
    Oct 31, 2014
    94
    How do you use Diodes as switches and not a rectifier?
    They can use Diodes as a SPST switch, but how?
    I thought Diodes rectify any bi-directional or bi-polar waveform
    I can't tell when looking at a schematic if the diodes are a switch or if they are rectifying the waveform, how can a technician tell?
    What is a Diode bridge used for?
  2. Lestraveled
    May 19, 2014
    1,957
    1,218
    A diode can be used as a SPST switch by controlling the bias. A diode will be on if it is forward biased and off when it is reversed biased.
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    ...which imposes the requirement that the bias current be switched somewhere else, and that the bias current be at least 10X bigger than the the current caused by the signal being switched.
    ps, might you be BillyMayo, or LeoWilson, or VinnyWilliams, or DanWalker, or several other aliases? that fellow is using these forums to learn what should better be learned in school, or self-study?
  4. watsongrey
    Oct 31, 2014
    94
    When using a Diode as a switch you need pull up resistor and a pull down resistor to bias the diode?
    When using a Diode as a switch, it still "rectifies" the waveform or does it pass an AC waveform right through the diode?
  5. alfacliff
    Dec 13, 2013
    2,449
    428
    use a couple of coupling caps, on on input and one on output, and it will switch audio or rf. when biased on and off of course.
  6. watsongrey
    Oct 31, 2014
    94
    So when a diode is biased with a positive and negative supply bias it will pass an alternating waveform and not rectify it?
  7. ian field
    Distinguished Member
    Oct 27, 2012
    4,459
    792
    As long as the half-cycle opposing the bias doesn't exceed the bias.
  8. watsongrey
    Oct 31, 2014
    94
    Yes so it doesn't clip the positive or negative cycles
    What is a Diode Bridge used for?
  9. ian field
    Oct 27, 2012
    4,459
    792
    Which one? - there's the regular full-wave bridge rectifier, and there's the diode ring mixer used in radio work.
    As a further twist - the regular bridge rectifier can also be configured as an DC controlled attenuator.
  10. ISB123
    May 21, 2014
    1,240
    531
    Diode bridge is used to turn AC into DC.
    Basically it works by flipping the negative wave into a positive one,now that is the case in full wave rectifiers.
    If you have 50 Hz and you rectify it with full wave rectifier you are going to end up with 100 Hz because negative waves were inverted in positive waves and filled the empty spot left by the AC.
    There are half wave rectifiers too they will just "block out" the negative wave and leave you with positive wave.
    You will have to use a capacitor to flatten the waves into a proper DC signal.
    Now this is a very crude explanation you can search for more info about bridge rectifiers on the net.
  11. watsongrey
    Oct 31, 2014
    94
    No, I'm not talking about a rectifier Diode bridge
    Diode bridge is like a SPDT or DPDT switch i heard when used as a Diode Ring mixer
    They use a Diode bridge like a switch
    I'm not sure how it's used as a switch
  12. ian field
    Oct 27, 2012
    4,459
    792
    I'd start by looking at ARRL (or RSGB) publications for articles explaining them.
  13. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Read the following pdf's.
    Bertus
