Diode and Resistor in series, but parallel with another diode and resistor
Discussion in 'Homework Help' started by volvicnatural, Dec 21, 2008.
  1. volvicnatural
    Dec 21, 2008
    If i had a diode and resistor in series with each other, in parallel with another set of diode and resistor in series. The resistors are 100kΩ and both the diodes are pointing in the same direction.
    How would you add the resistances?
    In finding the overall current, I've tried guessing the equivalent resistance as 0,50,100 and 200. None seem to give the right answer, but 70kilo ohms will. I'm not sure how to obtain this quantity though.
    (This is part of a wheatstone bridge question with five resistors, this particular branch will become R5, the fifth resistor where normally it would be a voltmeter/ammeter for a balanced bridge. The objective of the question if to find the overall current :eek:)
    Thanks for the anticipated help.
  2. leftyretro
    Nov 25, 2008
    394
    Is the applied voltage AC or DC and if DC will it be applied such that the diodes are forward biased or not. A complete diagram could be useful as sometimes these are trick questions that require no math.
    Lefty
  3. volvicnatural
    Dec 21, 2008
    I have attached the diagram of the diode-resistor arrangement. The applied voltage is DC. I read somewhere that for semiconductors, you add the parallel branches, but if that is so, then the effective resistance of this particular branch is 200 kΩ. Is this right?
    Thanks for the prompt reply!
  4. JoeJester
    Apr 26, 2005
    3,401
    1,218
    As drawn, your diodes are reversed biased, so there wouldn't be any current in the branches under the DC conditions you indicated.
  5. hobbyist
    Distinguished Member
    Aug 10, 2008
    773
    62
    I think, IF the diodes were biased in the forward direction, and enough current was flowing to cause the diodes to conduct, then you could subtract 0.7 v. from the supply volt. and then divide by the resistance in that branch, to solve the branch current.
    But as was stated, these diodes are NOT conducting. Therefor zero current.
  6. leftyretro
    Nov 25, 2008
    394
    Yes, if the drawing is correct, then it is most likely a trick question to test your knowlege of semiconductor current flow. As the diodes are reversed bias there will be no current flow through either resistor.
    Lefty
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    Basically the diodes aren't resistances, they are voltage drops. In any circuit you want to analyse figure the .7V drop into it, then work from there.
    In other words you take the power supply voltage, subtract 0.7VDC from it, and calculate the current from there.
  8. volvicnatural
    Dec 21, 2008
    If the current through R5 = 0, I end up with R1 and R3 in series but in parallel with R2 and R4, which gives me the overall resistance of 75 ohms that I needed for the right answer.
    Thanks a lot!
  9. hi-man
    Dec 24, 2008
    Hi.
    first apply the add voltage method to both of the resistance-diode sets connected in series. Then you will apply add current method to the parallel branches.
  10. JoeJester
    Apr 26, 2005
    3,401
    1,218
    Your diagram doesn't reflect what you just wrote.
