View attachment diode.pdf
Hi.
Referring to the attached image, please help to advise on case c).
0V across diode may cause by an ideal diode that is turned ON or a practicle diode that are OPEN. But i cant continue on the analysis .
And i also do not understand when it says 'check the source voltage'. The the 5V considered as the source voltage?
Thanking you guys in advance
Hi.
