I'm trying a lighting project and have the requirements of adding a dimmer. I only have 6V for the entire circuit, so I set up the separate circuit components in a parallel format to maintain the voltage. I'm thinking about using LED's for the majority of the lighting, but I'm stuck at the dimmer. Is there a way that I can get dimming LED's or use a simple low-voltage lamp in place of it?
