dimmer switch using scrs..
Discussion in 'General Electronics Chat' started by gayathri4686, Dec 15, 2004.
  1. gayathri4686
    Dec 14, 2004
    hi guys.....please help me with the theory on dimmer switches using 2 scrs..i searched the net ....could not find anything convincing......please explain me in a simple way...i was just taught the basics of scr....so.................please help me...it is important for me...it has to use scr's.......pleaseeeee :( :( :( :(
  2. cyberhehe
    Oct 6, 2004
    61
    You use 2 SCRs back to back as if you are using a triac and that is the basic of it.
  3. lightingman
    Apr 19, 2007
    374
    22
    Well here's one I designed earlier..
    I use these to control from 15 Watts to 20Kw (dependent on SCR).
    If you want the PCB layout, let me know>>
    Daniel.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    You may benefit from reading the material available on the AAC website that contains an SCR Tutorial.
    hgmjr
  5. Khosasih
    Mar 29, 2010
    Hi lightingman.
    i need the circuit 2x scr that u posted before. May u post again that circuits?
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The link to the PDF still works. The thread, however, is 3 years old.
  7. R!f@@
    Apr 2, 2009
    8,787
    771
    When were you born dude?
  8. y23c
    Apr 28, 2012
    Hi!
    I´m having a slight problem with Lightingmans circuit and would appreciate some help :)
    The problem is; I get an "control" puls roughly 14 degrees in to Q1 and Q3 but can´t control it´s position despite changing the control voltage from just above 0 to 10 volts. see pic
    First of, I have replaced some of the components to some I had available at the time;
    TR 1,2,3 -> BC548C
    TR 4 -> BD241C
    ZD 2,3 -> to two 6v2 diods in series
    Am I wrong to asume that this shouldn´t cause the problem?
    Any ideas to what I have done wrong?
    Cheers // Tomas
  9. R!f@@
    Apr 2, 2009
    8,787
    771
    Mods, can u move this to a new one.
