I have already posted on here before about the led circuit I want to put together to provide lighting for a microscope.
I want to power three dimmable 12 volt G4 fitting LEDs, with a dimmable LED driver such as this
http://www.ledhut.co.uk/drivers-fit...driver-for-powering-12-volt-led-lighting.html
I need a trailing edge dimmer switch (as far as I understand?), the trouble all the commercially available dimmer switches have a minimum load of 10 watts, whereas the bulbs I intend to power will be 6 watts, maximum.
Where can I get a dimmer that has a suitable minimum load?
I am not experienced or knowledgeable enough to make a complicated dimmer switch from components.
Alternatively, can I use a resistor to increase the load up to 10 watts so that the 10 watt minimum load dimmer will work ok? I gather its not a good idea as it will get too hot, or am I wrong?
Thanks for any help
Thanks for any help
