Hi, I have a recurrent problem with a dimmer, triac moc circuit. There is too much noise on the AC when the light is set on a specific phase. I isolated the problem but I just can't resolve it !!
When I use one of the tri-phase AC alimentation with a 1000w bulb, there are some of the others (bulbs wich are powered with another phase) that light up. And it happens only when the first one is set on 1/3 of the phase !
I saw a 3.5 volts noisy mini peak between the pin 1 of the triac (gate pin) and the pin 4 of the moc when the light is running on higher amplitude of other phase just enough to trigger the triac gate pin.
I tried to use inductor choke on it (between triac and moc) and put RC filter . No good news
Have you any suggestion ? Thanks !
