helo all,
i am trying to make a dimmer circuit for FAN(inductive load)..i have googled a lot in this.
so if any one having idea of any cost effective dimmer ic which have inbuilt optocoupler which is used for triggering triac(which conducts current at zero crossing)..as well the protection circuit for voltage surges against triac from ac load...
if no ic is there ,then if the circuit am i intending to make for dimmer circuit using optocoupler and triac(with some protection element) suitable for ac inductive loads??the dimmer ckt i am making is for home automation system??1 more ques is if the relays (driven by micro)can be used to control the dimmer circuit or the dimmer circuit is controlled by microcontroller itself??
any help from ur side would be highly appreciated.
thanks in advance
thanks in advance
