I am trying to do simulation for differential amplifier by using P Spice ,but the output is not right ,can please someone check what is the problem
the output should be 10 Vdc
Of course. Your amp is saturated. It's trying to get to 20V but can only get to 14.4V with a 15V supply.thanks ,I got 14.4 Vdc,i attach the p spice
Kilo-Volts, Milli-Volts, Volts or Amperes or something else?the gain is 100k/6010 =.0166 so vo= 600 * .0166=9.983 is this right or no
I get 14.4 not 9.98
The input doesn't need a separate ground reference for this circuit. That's provided through R5, R6, and R7.Takymounir, your circuit cannot work as a diff. amplifier because the input signals have no ground reference.
Crutschow, thank you. You are right. There was something like an obstacle in my head. Perhaps, because the circuit looks rather uncommon?The input doesn't need a separate ground reference for this circuit. That's provided through R5, R6, and R7.
sorry I change it it is 6 mega instead of 3 megaThe input doesn't need a separate ground reference for this circuit. That's provided through R5, R6, and R7.
TAKYMOUNIR, the differential gain is 100k/3010K (look here under Differential Amplifier). Don't know how you arrived at your value.
I use LF411,I WAS USING LETTER M AS MEGA AND THAT IS WHY MY SIMULATION WAS WRONG,SO SORRY FOR THISOK, I missed the resistor values being changed in the second circuit. For that the calculated output should be 9.98V, and that's what my simulation also showed, so don't know why your simulation is different. What op amp is that?
