Digital waveform
Discussion in 'Homework Help' started by full, May 7, 2014.
  1. full
    May 3, 2014
    225
  2. WBahn
    Mar 31, 2012
    18,085
    4,917
    You take a pencil and paper....
    and start by showing your best attempt to answer your homework problem.
  3. full
    May 3, 2014
    225
    thanks for response
    if can you help me
    I want key for waveform ... how I can do!
    thanks
  4. full
    May 3, 2014
    225
  5. WBahn
    Mar 31, 2012
    18,085
    4,917
    You're not making any sense. All three of your images are of the same circuit (or, if there is a difference, I'm looking right past it). One of them then has an answer. Why would the answer for the others be any different?
  6. JoeJester
    Apr 26, 2005
    3,400
    1,218
    The initial Q output for each flip flop is 1, according to your instructions. This is prior to the first clock pulse.
    Now, are you using positive or negative edge triggering J/K Flip flops?
    Your "answer" diagram illustrates a positive edge triggering from the clock pulse but does not follow the "instructions" of the problem.
  7. full
    May 3, 2014
    225
    can u see my answer:
    http://forum.allaboutcircuits.com/showthread.php?p=725889#post725889
