digital voltmeter using PIC 16f877a
Discussion in 'Homework Help' started by axy_872000, Feb 28, 2010.
  1. axy_872000
    Jan 7, 2010
    11
    allo every body...
    i need a little help...before that, i'm sorry if my english is bad...i'm not very good in english.
    i have built a digital voltmeter for my final year project using pic 16f877a. when i simulate the circuit using proteus isis, the circuit running well. however, the hardware part doesn't functioning at all. i wish if anybody out there could help me with this problem
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Post your schematic. Did you use proper power supply decoupling?
  3. axy_872000
    Jan 7, 2010
    11
    this is my schematic. in the hardware, i measure the output voltage and get 5.03 V. I want to use this circuit to measure the potential different in the water. the battery will be functioning as a probe where the +ve part connect to the LM324 and the -ve part connect to the ground.
