Digital Voltmeter Module
Discussion in 'The Projects Forum' started by Cerkit, Jan 8, 2009.
  1. Cerkit
    Thread Starter Active Member
    Jan 4, 2009
    275
    Does anyone know where I can get schematics to build a digital voltmeter module. Is it better to buy one??
  2. mik3
    Feb 4, 2008
    4,846
    63
    It is better to buy one. There are cheap ones if are an amateur in electronics and don't want to spend much. Try to find some in ebay.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Or just look for a digital panel meter. You can find them under $40.
  4. Cerkit
    Jan 4, 2009
    275
    Do you think I would be able to connect to the digital voltmeter module signals and use them to store the voltage values into a buffer??
    I mean to save me time from setting up the sampling circuit myself.
  5. mik3
    Feb 4, 2008
    4,846
    63
    I don't think you can do it practically because the PCB inside a multimeter is ver compact. What exactly you want to do?
  6. Cerkit
    Jan 4, 2009
    275
    The voltmeter readings will be used by software to do calculations for circuit analysis. So I thought it would be convenient to get a voltmeter and interface its signals to my software rather than build a circuit to sample the values.
  7. Alberto
    Nov 7, 2008
    169
    36
  8. mik3
    Feb 4, 2008
    4,846
    63
    If you can make soldering on the LCD inputs of the multimeter then you can do it but I don't think its practical.
    Also, there are some multimeters with PC interface (like this http://www.apogeekits.com/multimeter_dvm345di.htm) but I don't know how you can read the values from their software.
  9. Cerkit
    Jan 4, 2009
    275
    Ok. If I just want to make a circuit which can measure dc voltage and present the value on a signal how would I do it?
  10. mik3
    Feb 4, 2008
    4,846
    63
    Use an analog to digital converter IC and take its digital output to drive a display (seven segment or LCD) to view the result (measured voltage). If you want you can send this digital signal to a PC for processing etc.
  11. jj_alukkas
    Distinguished Member
    Jan 8, 2009
    751
    5
