Digital to Analog conversion in Multisim
xxxyyyba
Joined Aug 7, 2012
289
Here is schematic for Analog to Digital conversion:
Here are two Digital to Analog converters in Multisim:
Which one should I use? I want to connect it at output of ADC to get original sine wave. How should I connect it (which pins should I use)?
EDIT:
I found answer, however, other problem occurs :)
Here is schematic with 8bit DAC:
Here is transient analysis, showing input and output sine wave:
What are voltage spikes at output signal?
34,473
D/A converters can have spikes in there output when all all the bits are changing at an MSB rollover due to the fact that the interal switches can't all change instantly .
You need a low-pass filter or sample-and-hold at the output to smooth out the glitches.
