Digital temperature controller
Discussion in 'The Projects Forum' started by rasheed_it, Feb 17, 2012.
  1. rasheed_it
    Mar 26, 2011
    12
    I am currently working on the circuit attached. However I need to use 3- wire pt-100 as the temperature sensor instead of ds1620.... Please help.
  2. Felo
    Member
    Feb 20, 2012
    91
    13
    To build such a controller around a pt-100 you have to re-think everything starting with:
    -Pt's require a stable constant current source for them to work propperly
    -Feed the output to a good low tolerance resistor to turn the current into a measurable voltage
    -Feed this voltage to an ADC converting IC or MCU pin. (if ADC is supported)
    As it is, I would reccomend you to stick with the DS sensor.
    Good Luck.
