digital tachometer
Discussion in 'The Projects Forum' started by dasun_3000, Sep 25, 2008.
  1. dasun_3000
    Sep 25, 2008
    5
    IM gonna design a tachometer for a project. but im an amature in electronics.please help me to get information about designing my project.about the sensor device i should use, the microcontroller i can choose. what will be the code ..
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Take a look at this one individual's ATMEL AVR 8-bit microncontroller based tachometer project.
    hgmjr
  3. dasun_3000
    Sep 25, 2008
    5
    thanks.i just wanted to build a simple non contact tachometer.. thanks a lot.
  4. dasun_3000
    Sep 25, 2008
    5
    can any one suggest a suitable type of hall effect sensor for a tachometer..
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Not until we have some explanation of the application. Gear tooth, rotating shaft? What kind of environment? Will an optointerrupter and wheel work as well? What is the range of rotation?
  6. dasun_3000
    Sep 25, 2008
    5
    it should be a simple non contact digital tachometer. range would be 0-4000 rpm..im gonna use an optoisolator. yeah its for measuring the rpm of rotating shafts. i would be glad if you can help me..
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The principle is simple - one counts pulses that relate to the rotation for a period of time. What specifically is a problem for you?
