digital switch
Discussion in 'Homework Help' started by 0001T, Mar 18, 2007.
  1. 0001T
    Feb 28, 2007
    15
    hi, i am new to this forum.
    i am doing a logic assignment. One of the question asked was; 'Enable the temperature sensor by a digital switch such that it reads positive values of temperature'.
    Can i use the temperature switch described here?
    http://www.allaboutcircuits.com/vol_4/chpt_4/1.html
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That would not satisfy the requirement. What particular temperature sensor is to be used? If it's like an LM35, then a FET used as a switch would do.
  3. 0001T
    Feb 28, 2007
    15
    Thanks for the reply.
    The type of temperature sensor was not specified in the question but it was supposed to monitor temperature from 100degC to 500degC.
    Thanks.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The particular temperature sensor might have a lot of bearing on the solution to the problem.
