Digital Storage On Paper
Discussion in 'The Projects Forum' started by muhusidg, Feb 29, 2008.
  1. muhusidg
    Feb 29, 2008
    Hello friends,
    I was thinking if we can print data on a paper like we write it on CD.read and write through a device may be kind of combo orinter and scanner.
    what is the procedure of converting a digtal data in to a printable form.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I use a complicated electromechanical device known as a "printer". ;)
    Actually, your concept has been around for many, many years. Early IBM computers had "card readers", that would read the holes on stacks of punched cards. There were also "card punch" machines that had a keyboard similar to a typewriter; it would at once punch holes and print the text on the top of the card, so it was readable by both machines and humans.
    In the 1980s, there were a few computer publications that would publish BASIC source code with a scan-able strip next to the code. If you had one of the handheld scanners, you wouldn't have to type all of the code in.
    Here in the US, computer-readable bar codes are on products of all kinds at stores. It is easier for a store to maintain inventories and change prices if they don't have to physically re-label all of the products they carry.
  3. nomurphy
    Aug 8, 2005
    567
    12
    Typically, 8-bit ASCII
    Although one may well come up with more complicated algorithms:
    Consider that if an 8-1/2" x 11" page with 1" margins can hold 56 x 48 (2,688) "M" characters in Times New Roman 10 font.
    So, if you expand on the idea that you can encode sixteen bits in 0-F, and could encode thirty-two bits using most of the alphabet (English, anyways), and that by using special characters you could expand that to encode 64-bits (8 bytes) into a single character...
    2688 X 64 X 8
    Well then, you could get ~1.2Meg of data on a sheet of paper. The old 3-1/2" floppies were probably better.
    And, how well is this paper going to hold up?
    What if your dog eats your programming?
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Byte Magazine had a series of articles in the late 70's about a system called paper bytes that used a barcode like system with a hand held sensor.
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    What about optical character recognition software?
