I have had one question of the demodulator, AD8348 since the sensitivity of the TETRA terminal was tested.
In ETSI standard, BER should be lower than 3% at -112dBm of input power. Our terminal has about -115dBm of the sensitivity.
When the terminal input is connected to the Tetra test set and then modulated signal is injected to the terminal with about -115dBm input power, receiver may not recognize the signal from Tetra test set.
But if higher level ( about -80dBm to -90dBm) is injected , the receiver can accept the random signal, and then up to -100, -110, and -115dBm the receiver is working well.
I guess something in demodulator is wrong or may be dc offset problem. So I have searched troubleshooting about the demodulator and digital receiver.
What do you think about this problem? Are you heard likewise problems? Help me know.
