Digital potentiometer between +/- 2.5V
atferrari
Joined Jan 6, 2004
4,771
My previous experience with digital potentiometers is only using them as voltage dividers with one end to ground but this time I intend to replace Rf1 in the attached circuit (filter) using a 100K digital potentiometer in rheostat mode.
Just in case I verified that both ends are at 0V DC.
To accommodate a signal of 4V pk-pk, I should provide a dual supply of +/- 2.5V to the digipot.
My question: is it any simple way to ensure that the micro in charge (working between +5 and 0V) can communicate with the IC without damaging it?
ifixit
Joined Nov 20, 2008
652
The end of Rf1 going to the - input is a virtual ground. However, failure modes and start-up conditions could cause either end to be at ±15V.
Choose a part that has at least a ±15V supply range to be safe. The digital control inputs should have a separate logic supply (5V) and is not effected by voltages on the resistor.
What is the digital pots part number?
Regards,
Ifixit
atferrari
Joined Jan 6, 2004
4,771
Found a much simpler solution: moving all non inverting inputs to +2,5 V. The digipots will be centered in the middle.
Thanks for your time.
