Attached is the spec sheet for the digital pot and my schematic.
I am taking the output of three mechanical pots and based on certain conditions I am either adding or subtracting voltage from the mechanical pots to get a voltage output that represents a different position of the mechanical pots.
My problem is I am smoking the digital pot. The max voltage on one leg of the digital pot is 3v. It fails when I input the max 3v into the digital pot. So I thought to myself, what the hell I will read the spec sheet for the pot, maybe I am exceeding the max amperage tolerance of the digital pot. Here is a line from the spec sheet
AXBX, AXWX, BXWX . . . . . . . . . . . . . . . . . . . . . . ±20 mA
So if I have 3v, I need a 150 ohm current limiting resistor on the leg getting the 3v. So I lift up the pin and place a SMT resistor in between the SMT pad and the pin. It failed again.
So am I reading the spec sheet correct? Maybe I am just so close to the max amperage I need to go with a higher value current limiting resistor.
On the schematic the digital pot is on the bottom left corner
Toby
Toby
