Don't jump to conclusions so quickly.
If IC48 is 74HC04, shorting pins 1 and 2 while A15 is driving pins 1 and 2 together could very well put the inverter into the linear region at 2.5V We still don't know if the A15 output is blown.
Have you installed the RESET push button?
As I said, shorting the input and output of a CMOS inverter should make it a linear amplifier. There is still a chance that A15 from IC1 is ok.
We need to find out what is preventing KPU from accessing its ROM code.
An inverter is an inverting amplifier with high gain. If you feed back the output to the input, you are applying negative feedback as you would in a linear op-amp circuit. With a 4000 series inverter you can in fact create a linear amplifier by feeding the output back to the input via a series resistor. The output attempts to bias the input at a voltage halfway between VDD and VSS.
With a 74HC04 inverter, feeding the output back to the input via a resistor creates an oscillator. CMOS output gates are current limited hence it is possible that the KPU A15 output could still be ok.
Wait 15 years, then come and revive this thread again. We will pick up right where we left off.Hi guys,
Quick update. Due to major frustration and lack of room. I packed up this unit and put it in storage. I just had no room in my house to have this monster sitting around and basically it was giving the grumpys.
One day, hopefully with more experience on my behalf, I will revisit the unit. (I am waiting to get a new shed build)
Steve.
by Duane Benson
by Duane Benson
by Jake Hertz
