Ok, we are going to shift gears.
Keep in mind that ideally we would hope for a simple fix such as a shorted bypass capacitor and a blown inductor in the VDD power feed.
With your scope we are going to look for bus activity starting with the first major components, beginning with IC1.
At Bottom Right of the board, locate IC48 SN74HC04 and probe the first inverter at pins 1 and 2. Look for signal activity. This is CE' on the main ROM.
At IC6, D27C256AD-15 (XG879), probe the data bus at pins 11- 13, 15-19 and look for activity on each pin.
All we are looking for is that the pins are changing between about 0V and 5V.
