Digital phase shifter
Discussion in 'General Electronics Chat' started by DominusDRR, Sep 3, 2009.
  1. DominusDRR
    May 25, 2009
    26
    Hello.
    Are there a way to make a digital phase shifter with flips flops and logic gates?
    Thank you.
  2. mik3
    Feb 4, 2008
    4,846
    63
    A simple phase shifter can be made with a NOT gate due to its propagation delay. The more gates you add in series the more the phase shift.
  3. DominusDRR
    May 25, 2009
    26
    Please. Do you have a circuit that can share?
  4. mik3
    Feb 4, 2008
    4,846
    63
    Connect two NOT gates in series (the output of the first in the input of the second). Then connect you signal on the input of the first. You will get a delay of about 50ns to see the signal on the output of the second gate.
  5. DominusDRR
    May 25, 2009
    26
    Thanks But I need phase shifted (90º, 180º, 270º) etc
  6. mik3
    Feb 4, 2008
    4,846
    63
    180 is easily implemented with a NOT gate. To achieve other phase shifts with a delay you have to know the signal's frequency and calculate the appropriate delay otherwise you need more complex circuits which read the signal and perform the required delay.
  7. DominusDRR
    May 25, 2009
    26
    But if the signal is PWM and high frequency? (100MHz)
  8. mik3
    Feb 4, 2008
    4,846
    63
    First why do you need such a high frequency PWM signal?
    How you generate it?
  9. DominusDRR
    May 25, 2009
    26
    PWM signal comes from the comparison of a signal 1MHZ with a triangular signal of 100MHz
  10. mik3
    Feb 4, 2008
    4,846
    63
    And you want to phase shift one signal as to vary the duty cycle?
    But why you need such high frequencies?
  11. DominusDRR
    May 25, 2009
    26
    Yes. I want to phase shift the duty cycle in 90 ° and add the two signals (input and output) to increase the duty cycle time.
  12. mik3
    Feb 4, 2008
    4,846
    63
    Why don't you use a triangular wave, a comparator and a pot to generate PWM from 0% to 100%.
    Feed the triangular wave on one input of the comparator and the output voltage of the pot to the other.
  13. DominusDRR
    May 25, 2009
    26
  14. DominusDRR
    May 25, 2009
    26
