The load on my cct has a maximum current rating of 2.25 amps. The source voltage won't exceed 5.75 volts. I need to monitor the voltage and desire to monitor the current as well. Absolute accuracy is not critical. I am using a DPM that requires resistors be installed per the attached instructions(page 1 for voltage, page 2 for current). I plan to use a DPDT switch to switch the DPM between current and voltage with the output to the DPM connected to the common poles.
Would the attached schematic work(page 3)? The voltage drop across the .1 ohm resistor (A and B) would be used for the current measurement. The voltage would be read across the 100K resistor( C and D).
