Digital Out - Ref change
jismagic
Joined Sep 7, 2013
77
Whats the easiest/efficient way to take a digital out from a micro and then change the reference - (0-5V) to (0-12V) or (0-18V). Also increase the source and sink current.
thanks
jis
jismagic
Joined Sep 7, 2013
77
I forgot to mention - i do not want to build a circuit, but use something that is already available. Use an IC which can do it for me, or a module i can buy easily or replace easily
thanks
jis
absf
Joined Dec 29, 2010
1,968
This type of circuits is usually known as voltage level shifter and is used between 3.3V and 5V logic devices. You may do a search on eBay or Sparkfun to see if such product is available using keyword "voltage level shifter".
A cmos logic chip 'HCF40109BE' is also a logic shifter capable of 0-3V to 0-18V. It has separate Vcc and Vdd. You can download the datasheet of this chip from the net easily.
Allen
pwdixon
Joined Oct 11, 2012
488
thanks
jis
A transistor solution will allow for a wide range of level shifts and need be no more than a transistor and perhaps a resistor. That's got to be easier than wiring up an IC surely?
pwdixon
Joined Oct 11, 2012
488
Allen
One of these chips might not fulfill the requirement to higher output current though.
absf
Joined Dec 29, 2010
1,968
Quite true. But the OP never specify how much current he wanted to source ot sink. A transistor can either sink or source current but not both. Unless it is connected in a totem-pole way.
May be the OP should spell out his need in more details.
Allen
AnalogKid
Joined Aug 1, 2013
11,036
The ULN2001 gets you 7 translators. Each is a darlington transistor arrangement, so it acts as a logical inverter and each output needs a pull up resistor. Also, it does not pull down all the way to GND. Low outputs sit at 0.65-0.8V depending on current.
ak
pwdixon
Joined Oct 11, 2012
488
However, a single mosfet transistor could be selected for whatever minimum voltage pulldown you'd like to chose based on current loading and RdsON. And you wouldn't need a pullup resistor on the input or output either.
