digital multimeter
Discussion in 'General Electronics Chat' started by carolb4, Feb 20, 2010.
  1. carolb4
    Feb 20, 2010
    I have a Commercial Electric handheld digital multimeter. I'm trying to test parts of an icemaker and was told from this website to: Conduct this test with the refrigerator unplugged. Test the mold heater for resistance using a multitester. Set the multitester to the ohms setting X1. Place one probe into the hole labeled "H" and the other probe into the hole labeled "L". The multitester should read in the range of 60 to 90 ohms.
    This multimeter does not have X1 on the meter scale. There is 200, 2K, 20K, 200K, etc.
    I don't know how to test. Please advise.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The 200 scale reads to 200 ohms. (0 - 199).
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    If 200 is the lowest scale then that is the one to use. X1 refers to the "times 1" scale.
    hgmjr
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    I have replaced two icemakers over the years. It is my humble opinion that you will be better served to replace the icemaker with a new one. You will benefit in the long run.
    hgmjr
  5. someonesdad
    Jul 7, 2009
    1,585
    141
    The nomenclature "X1" is obsolete and comes from the days when multimeters were analog devices. The basic idea was that you multiplied the resistance reading on the analog meter scale by the factor after the X. Modern digital meters require no such conversions on the part of the user (other than, perhaps, knowing about SI prefixes).
  6. VoodooMojo
    Nov 28, 2009
    503
    53
    I always liked 10 to the 24th.... yotta, yotta, yotta....
  7. VoodooMojo
    Nov 28, 2009
    503
    53
    SI index reference
  8. retched
    Dec 5, 2009
    5,201
    313
    Don't you hate jokes you gotta explain..or should I say yotta.
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    Attoboy is faint praise indeed.
  10. someonesdad
    Jul 7, 2009
    1,585
    141
    Let us know if you see a multimeter using that prefix -- should be a pretty capable meter... :p
  11. retched
    Dec 5, 2009
    5,201
    313
    If you could carry the shunt. It would probably weigh a good bit. and have a huge heat-sink.:D
  12. VoodooMojo
    Nov 28, 2009
    503
    53
    sure, make fun of me, but remember:
    160,217.897 Coulombs is a yotta electrons:p
    nyuk, nyuk, nyuk....
    __________________
    -rm-
  13. retched
    Dec 5, 2009
    5,201
    313
    He said "THATS A YOTTA ELECTRONS!!!":D
    ---calm down, now, people---
