Digital modulation feature extraction using unwrapped phase
Discussion in 'Wireless & RF Design' started by LeonardoHonda, Aug 29, 2013.
  1. LeonardoHonda
    Aug 29, 2013
    I created a BPSK signal in Matlab and I'm wanting to extract the unwrapped phase from the instantaneous phase obtained. The detail is that the result will apply an equation to get the centered non-linear component of the instantaneous phase which is given for "phi_NL" in the code below. This nonlinear phase should be between a value close to zero and pi, which is in accordance with the signal, as occurs in the BPSK phase shift of pi in each transition from 0 to 1 or from 1 to 0, in the encoding to be transmitted.
    I've used the function unwrap Matlab, but the nonlinear phase ends infinitely increasing or decreasing. Researched more about the unwrapped phase in the internet and got the function below. However, the same result was obtained earlier. But changing the limits of "difference" to pi/2 and using a sine to create the modulated signal, the result is a phase that varies between zero and Pi, as expected.
    I wonder if I can modify this threshold unwrap that way, since I can not get the expected result with the original code. Another thing I would like to know what is the relationship between this threshold with the cosine and sine used in signal modulation of the BPSK signal.
    The full paper is in the address below:
    I found this code for unwrapping phase in this link below:
    __________________________________________________ __________________________________
    ns = 100; % Number of symbols
    fs = 100*10^6; % Sample frequency
    fc = 10*10^6; % Carrier frequency
    rs = 500*10^3; % Symbol rate
    nb = fs/rs; % Number of samples per symbol duration
    Ts = 1/fs; % Sample interval
    % Creating the modulated signal
    r = rand(ns,1); a = zeros(ns,1); n = zeros(ns*nb,1);
    for i=1:ns
    if (r(i)<0.5)
    a(i) = 0;
    a(i) = 1;
    for i=1:1:ns
    for j=nb*ind+1:nb*ind+nb
    n(j) = a(i);
    z = zeros(ns*nb,1); % BPSK signal
    for i=1:ns*nb
    fase = n(i)*pi;
    z(i) = sin(2*pi*fc*i*Ts + fase); % BPSK signal
    x = hilbert(z);
    phi = angle(x); % Instantaneous phase
    c = zeros(ns*nb,1);
    % The linear component of the instantaneous phase
    for k = 1:ns*nb
    c(k) = 2*pi*fc*k/fs;
    % Unwrapped phase function
    difference = zeros(ns*nb,1);
    phi_uw = phi;
    for i = 2:ns*nb
    difference = phi(i) - phi(i-1);
    if difference > pi/2
    phi_uw(i:end) = phi_uw(i:end) - 2*pi;
    if difference < -pi/2
    phi_uw(i:end) = phi_uw(i:end) + 2*pi;
    % The centered non-linear component of the instantaneous phase
    phi_NL = phi_uw(1:1000) - c(1:1000);
    % PLOTS
    figure; plot(n(1:1000));
    figure; plot(phi_NL);
    figure; plot(phi_uw(1:1000));
