Digital Logic
Discussion in 'Homework Help' started by Matthews, Dec 12, 2011.
  1. Matthews
    Dec 12, 2011
    !. Write F= ABC +AB'C' in Nand and Nor Form, Draw A logic Gate implementation of both solutions. Varify that they are equivalent for A=B=C=0
    2. Perform an unsimplfied Max-term expression of F=(A,B,C)= Ʃ 1,2,3.
    Is the result in SOP or POS form?
    3. Design a 1 bit adder with carry in using only NOR gaes.
    4. An 8:1 MUX input is written in hex AF, what is the logic level on each of the data input pins?
    5. How many select pins are on a 8:1 MUX?
    6. specity the output of the MUX if the control select is sat at : S0=1,S1=1,S2=1 with the above inputs.
    7. Prove that 5+(-5)=0 in 4bit 2's compliment​
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    Welcome to AAC!
    This is the Homework Help section. We provide help to students with their homework voluntarily, but in return we ask them that they make the first step and try to solve their own problem.
    So please post any work or efforts you have done towards solving your questions. We 'll talk and comment over them.
