Digital Logic Comparator
Discussion in 'Homework Help' started by squartle, Dec 31, 2010.
  1. squartle
    Dec 31, 2010
    Can somebody please tell me how the following circuits can be created?
    1- A comparator circuit that outputs 1 whenever two 4bit signed numbers represented in Sign & Magnitude are equal.
    2- Same circuit but this time, the two numbers are represented in 1's complement.
    3- Also the same circuit, with the two numbers represented in 2's complement.
  2. shteii01
    Feb 19, 2010
    3,515
    515
  3. Ron H
    Apr 14, 2005
    7,050
    657
    If you only need an indication of equality, then you only need to do bitwise comparisons. Hint: An exclusive OR is a 1-bit comparator.
