So while the input is low nothing happens, when the input is high, the chopper(triac cutting up sine wave) is active at a preset xx mS delay, or is the delay adjusted digitally as well?@thatoneguy:i have to design an alternative to microcontroller based digital firing angle.say,if the input=0v(logic0),it detects the zero-crossing.then after a certain delay,when the input jumps to 5v(logic1)....thyristor is fired!!!
makleo, you are making some confusion. Detecting the zero crossing is not a digital function but an analog function, since you are exploring the sin wave hunting for the zero value. You will generally use a comparator, a bridge rectifier and a transformer for this purpose. Now if your circuit works you will see on your scope a pulse rising every time the sin wave cross the zero. Now, to dim your lamp (mind you got to be a resistive load) you need to delay the firing of the triac and for this purpose you have suggested to use a 555, (here again an analog component) setting up the proper RC you will handle the required delay to obtain your dimmer.i have to design an alternative to microcontroller based digital firing angle.say,if the input=0v(logic0),it detects the zero-crossing.then after a certain delay,when the input jumps to 5v(logic1)....thyristor is fired!!!
Yes, that is a way to do it, you only need to write the code to provide the input of delay, then timers for triggering the triac, it's mostly software/programming work from here.i hope the confusion is over now........8051 with keypad and LCD interfacing is used for delay.........optocoupler 4 firing thyristors.i think it'll be put together as follows:
"AC input(60Hz)--->zero-detector--->8051microcontroller--->optocoupler--->thyristor"....
isn't it?time 2 simulate it on proteus................!
Thread starter | Similar threads | Forum | Replies | Date |
K | 4K signal generator from digital circuits | Digital Design | 6 | |
M | Different readings when testing a diode on-board and off-board | Test & Measurement | 4 | |
M | Digital Clock using LogicWorks 5 ..#2 | Homework Help | 1 | |
W | Protecting MCU digital input | General Electronics Chat | 3 | |
M | digital firing angle using 8051 | Homework Help | 2 |
by Duane Benson
by Robert Keim
by Duane Benson
by Jake Hertz
