Digital filtering
Discussion in 'Programmer's Corner' started by Cerkit, Jan 19, 2009.
  1. Cerkit
    Thread Starter Active Member
    Jan 4, 2009
    275
    Hi. I have been given some audio files and need to make filters in MATLAB to remove some intentionally added noise. I know how to make filters but not sure how to determine what to let through and what to block how can I identify this from the audio files??
  2. mik3
    Feb 4, 2008
    4,846
    63
    I don't know how audio files work but set the filter cut off frequency at 20 kHz.
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Assuming you know how to characterise the noise, i.e. frequency components, and have an appropriate filter characterised in the frequency-domain, then you need to read in your audio file to Matlab (this will, depending on function, likely be the time-domain representation). Then you need to convert the time-domain representation to a frequency-domain representation via the Fourier Transform (function fft), and then apply your filter via simple multiplication ([fd_sig].*[filter]).
    That is a basic model, however you specific case may be more involved.
    Dave
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    Why would someone intentionally add noise to a digital audio file?
    John
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    John,
    Aside from the example here of doing it for the purposes of creating an academic exercise to simulate a real audio filtering application, the most obvious real world example I can think of is audio watermarking which can be used in DRM, where the watermark is the embedded "noise".
    Dave
  6. Cerkit
    Jan 4, 2009
    275
    Hi. I've made a butterworth IIR filter in matlab using fdatool. How can I apply it to a .wav audio file???
  7. KL7AJ
    Nov 4, 2008
    2,047
    294
    You need to convert the wav file to a flat data file. I think there's a matlab tool for doing just that.
    eric
  8. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Cerkit, I have merged this thread with your previous one as they are fundamentally asking the same question, and the advice I gave last time is applicable here.
    Firstly, I am vaguely familiar with the fdatool function, can you tell us what the output from it is? For a Butterworth filter you want an [n x 1] matrix defining the magnitude Vs Frequency characteristic of the filter - in fact each element in the matrix will describe the magnitude at discrete frequencies so I imagine it will also give you a frequency resolution (i.e. the difference in frequency between adjacent elements in the matrix).
    You then need to read in the wav-file using the wavread function, which will give you a time-domain description of the wav-file. Then you need to apply the Fourier Transform, function fft, to get the wav-file in the frequency-domain. You will need to ensure that the frequency elements in the frequency-domain representation of the wav-file correspond to the appropriate frequency elements in the Butterworth filter matrix. It is then a simple process of multiplying these two matrices, which performs the filtering process. Then apply the Inverse Fourier Transform, function ifft, to the multiplied matrix to get the filtered wav-file back in the time domain. Finally, use wavwrite to write the filtered time-domain representation of the wav-file into an actual Microsoft wav-file that you can listen to.
    Dave
  9. KL7AJ
    Nov 4, 2008
    2,047
    294
    The addition of noise to digitized audio "dithering" is actually fairly standard practice. It adds some randomness the the least significant bit during the sampling process, which actually decreases "sampling distortion" in one of the great paradoxes of nature. :)
    http://www.earlevel.com/Digital%20Audio/Dither.html
    This is from my brother-in-law's web site, EarLevel Engineering. He's one of the co-creators of MIDI, by the way. :)
    eric
    eric
  10. Cerkit
    Jan 4, 2009
    275
    Hi. Ok so I have the Xk = fft(wxn) so Xk is my wav file in frequency domain. My filter is made of three butterworth filters cascaded and when I export the coefficients it creates a variable which is of type 1x3cell. I try multiplyng the XK and coeff but its not working. Do i have to change the coeffiecients somehow before multiplying??
  11. Cerkit
    Jan 4, 2009
    275
    Or rather I can export them individually as the SOS and scaling factor but dont know how to cascade them using code or apply the filter for that matter??
