Digital fan tester..
Discussion in 'The Projects Forum' started by thinkerbelle, May 19, 2015.
  1. thinkerbelle
    May 19, 2015
    11
    I am currently working on my final year project:building a digital fan tester system for a Sunon brushless dc fan that will be used without necessary taking the fan out...I plan to incorporate use of LCD & pic microcontroller.
    Kindly advise on how to go about this?and advise on how to program/interface LCD with microcontroller.
  2. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    I cannot quite see how you are going to accomplish this when the BLDC controller is embedded in the fan itself.
    There is maybe current and the validity of the fail sense, but what other details else where you hoping to obtain?
    Max.
  3. wayneh
    Sep 9, 2010
    12,371
    3,224
    Fans move air. If the blades are not damaged, rpm will give a proxy measure of fan performance. But I don't see an rpm meter as much of a final year project.
  4. thinkerbelle
    May 19, 2015
    11
    Thanks Max really appreciate your feedback...how would you have rather gone about this?
  5. thinkerbelle
    May 19, 2015
    11
  6. thinkerbelle
    May 19, 2015
    11
    Thank you wayneh,
    Yes it seems like a very easy project for final year :)...but there is a special reason why I am undertaking it.
  7. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    What is it exactly you are attempting to qualify or measure?
    Max.
  8. wayneh
    Sep 9, 2010
    12,371
    3,224
    What aspects of the fan do you want to test?
    [scooped again by Max!]
  9. thinkerbelle
    May 19, 2015
    11
    Basically how to detect whether the fan is running about its correct speed.
  10. thinkerbelle
    May 19, 2015
    11
  11. DickCappels
    Aug 21, 2008
    2,753
    665
    Just test for what fans are supposed to do:
    Air pressure in a fixture or flow in CFM (cubic feet per minute) possibly taking temperature into account.
  12. wayneh
    Sep 9, 2010
    12,371
    3,224
    So a tachometer would give you all you need?
  13. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    You would need to know either what the rated rpm is at the CFM figure for the fan or at least the normal rpm figure, the latter could be done with a retro-reflective tach style sensor to read the rpm.
    Max.
  14. thinkerbelle
    May 19, 2015
    11
    Was wondering if I can monitor the square wave coming from the fan by a microcontroller input....then build in the sofware detection loop for this?
  15. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    Where exactly on the fan were you thinking of obtaining the square wave?
    Max.
    thinkerbelle likes this.
  16. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    I see on the Sunon site they give quite detailed performance information for each model, they all appear to have one DC supply via the 2 leads.
    Max.
  17. alfacliff
    Dec 13, 2013
    2,449
    428
    if you change to the other type of fan, the one with three leads, the third lead is a temprature sensor, that would give you the most important information, whether the fan was cooling or not.
  18. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,683
    1,295
    If you are testing a fan that is installed in equipment, you can put a white dot sticker on the hub and use an optical tachometer to determine the speed.
    You can use an acoustic microphone to pickup the frequency of the fan blades against the fan motor struts, and divide that by the number of blades to get the speed.
    You can use an inductive sensor like a coil of wire on a ferrite rod to pickup the switched magnetic fields, and divide that by 2 or 4 to get the speed.
    If this is on a test bench, you can insert a small current shunt resistor in series with the ground lead of the fan, look at the voltage across the resistor, and divide that by 2 or 4 to get the speed.
    You can place a hall effect sensor near the motor hub to sense the magnetic fields, and divide that by 2 or 4 to get the speed.
    ak
  19. wayneh
    Sep 9, 2010
    12,371
    3,224
    And if the fan's inlet is plugged, you'll get lots of RPM and zero airflow, like a plugged vacuum cleaner. ;)
  20. MaxHeadRoom
    Jul 18, 2013
    10,831
    2,501
    Plus lower current!:)
    Max.
