Digital Electronics
Discussion in 'Homework Help' started by coo0004, Dec 6, 2006.
  1. coo0004
    Dec 6, 2006
    hi guys
    i am new to this forum and i am currently undertakin an electronic engineering degree and i thought it would be a good idea to join, anyway at the moment i am having a big problem with boolean algebra and all i can find on the internet is simple stuff. anyway if anyone can help me figure all this out it would be much appreciated.
    for example:
    __ _ _
    (ABC + ABC + ABC + ABC)(A+B)
    and
    ___ _ _ _ __ _ _
    ABC + ABC + ABC + ABC + ABC + ABC
    thanks heaps guys
  2. coo0004
    Dec 6, 2006
    Sorry guys disregard those last problems
    these are the correct ones, (' represents not)
    A'B'C' + A'BC' + A'BC + AB'C' + AB'C + ABC'
    and
    (AB'C' + AB'C + ABC + ABC')(A+B)
    thanks again
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    What are you trying to do, simplify the expressions?
    Dave
  4. coo0004
    Dec 6, 2006
    yeh i was trying to minimise the equation. any help is appreciated
  5. m4yh3m
    Apr 28, 2004
    186
    42
    I always threw those things into Electronics Workbench and let it simplify it :p
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    The first one A'B'C' + A'BC' + A'BC + AB'C' + AB'C + ABC':
    Take out common factors B'C' ; BC' ; C
    B'C'(A'+A) + BC'(A'+A) + C(A'B+AB')
    (A'+A) = 1
    Therefore:
    B'C' + BC' + C(A'B+AB')
    Take out common factor C'
    C'(B'+B) + C(A'B+AB')
    (B'+B) = 1
    Therefore your simplified expression is:
    C' + C(A'B+AB')
    The second one will use the same techniques as the first but look at taking out common factors AB and AB' from the first bracket, don't multiple out the two brackets.
    If you want further advice, or wish to run your answer past us, post it up and I'll be glad to check it. I am also moving this to the Homework Help forum.
    Dave
  7. dina
    Member
    Nov 12, 2006
    19
    Hi
    here's a simplification for the first problem:
    C' + A'B + AB'
    for the second one:
    it's simply A
  8. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Do you care to embelish on how you simplied the first expression to C' + A'B + AB' - where did the C go?
    Dave
  9. dina
    Member
    Nov 12, 2006
    19
    hi Dave...
    i used the karnaugh map to simplify both the problems
    if u need a help with karnaugh maps i'll be glad to help
  10. beck
    Member
    Nov 27, 2006
    26
    yup,
    K-Maps are the best.
  11. dragan733
    Dec 12, 2004
    152
    A'+AB=A'+B
    A'(B+B')+AB
    A'B+A'B'+AB+A'B
    A'B=A'B+A'B
    A'(B+B')+B(A+A')=A'+B
  12. Sonofjustice
    Jul 3, 2008
    Yeah There Is Also This Formula Saying X'+XY= X'+Y
  13. Ratch
    Mar 20, 2007
    1,068
    Dave,
    Sure, use the identity X +X'Y = X+Y where X=C', X'=C, and Y=A'B+AB'
    Proof of The Identity:
    The dual of X +X'Y is X(X'+Y) = XY
    The dual of XY is X+Y, so the identity is proved. Other ways exist to prove the identity. Ratch
  14. Ratch
    Mar 20, 2007
    1,068
    beck,
    Nope, not when the number of variables is greater than 5 or 6. It blows your mind to try to interpret that many variables variables on a K-map. Try:
    P(A,B,C,D,E,F) = SOP(6,9,13,18,19,25,27,29,41,45,57,61)
    Tabulation methods like the Quine-McCluskey method guarantee the best simplification and are applicable to computer operations.
    The answer to the first problem I got from the Quine-McCluskey method was A'B+AB'+C' .
    For the second problem, by inspection it is easily seen that
    (AB'C' + AB'C + ABC + ABC')(A+B)=(AB'C' + AB'C + ABC + ABC') .
    Then = (AB'C' + AB'C + ABC + ABC')= AB'(C'+C)+AB(C+C') = AB'+AB = A(B+B') = A
    Ratch
