Digital Electronics help
Discussion in 'Homework Help' started by aniskazi, May 6, 2014.
  1. aniskazi
    May 3, 2014
    44
    Design a logic circuit of electronic lock with inputs P,Q,R so that output S is HIGH whenever Q=R. Using NAND gates.
    P Q R S
    0 0 0 1
    0 0 1 0
    0 1 0 0
    0 1 1 1
    1 0 0 1
    1 0 1 0
    1 1 0 0
    1 1 1 1
    I made the eq as : P' Q' R' +P ' Q R + P Q'R '+ PQR ... ' = compliment taking QR common
    QR( P'+P) + Q'R'(P'+P)
    QR + Q'R'
    is this eq: correct?
  2. tshuck
    Oct 18, 2012
    3,531
    675
    If the output doesn't depend on one of the inputs, the simplified equation shouldn't have it, right?
    Your truth table has some places where Q=R, yet S=0...
    Edit: The OP has come back and modified the post, so the answer provided is not what was originally there....
  3. aniskazi
    May 3, 2014
    44
    yes edited the post sorry about that are you talking about the P input? that it shouldn't be in the circuit?
  4. tshuck
    Oct 18, 2012
    3,531
    675
    I'm saying that if the output is only dependent on Q and R, it stands to reason that the function that describes the output should only consist of Q and R, in a reduced form.
  5. aniskazi
    May 3, 2014
    44
    okay so if I only include Q and R in it so it will become with the equations as:
    Q' R' + QR + Q' R' + QR
    This will be the eq....
  6. tshuck
    Oct 18, 2012
    3,531
    675
    I'm not suggesting that you simply omit the P, but rather that, as a check, your final equation cannot have a P variable.
    I would suggest either posting your K-map or Boolean algebraic steps so we can comment...
  7. aniskazi
    May 3, 2014
    44
    Got rid of the P in the final eq:
    QR + Q'R'
    correct my truth table with the eq and the final eq is this correct? I'm trying to make the truth table will show you when it's done :)
  8. tshuck
    Oct 18, 2012
    3,531
    675
    There you go.
    You should learn to check your answers by comparing your simplified results against the original, that way, you needn't ask if you are right, but you'll know it.
  9. aniskazi
    May 3, 2014
    44
    you mean to say that the eq that I got I should put the inputs and verify the results right? By the way made the circuit check it out please :)
    http://postimg.org/image/tx0s7njqb/
  10. tshuck
    Oct 18, 2012
    3,531
    675
    Precisely. If the functionality is any different, it is, by definition, not a simplified function. So, ensuring the same output for the same inputs will allow you to check the results yourself.
    Looks good.
    Another way to check this is to map out the truth table (like above).
    It is typically encouraged for you to upload images to this forum as links to other website will eventually break. You can do that by clicking the paperclip icon while posting.
    aniskazi likes this.
  11. full
    Member
    May 3, 2014
    225
    I think the answer is true:
  12. tshuck
    Oct 18, 2012
    3,531
    675
    Hi full,
    While I'm sure you can do your own homework, doing other people's homework does not benefit them.
    Please do not post answers as we try to teach people here and it's probably safe to reason the OP has seen many problems worked before. Showing the OP one more problem is unlikely to give them the clarity that comes from struggling through and grasping a problem one step at a time.
  13. full
    Member
    May 3, 2014
    225
    ok ,I'm sorry,
    I new in this forum
  14. tshuck
    Oct 18, 2012
    3,531
    675
    No worries.
    Just keep your answers to your threads.:)
    brahms likes this.
  15. aniskazi
    May 3, 2014
    44
    I had one more question in my mind that if I have got a circuit in which only AND gates have been used and I have to remake it using only NAND gates than for every one AND gate I have to use TWO NAND gates is that true?
  16. tshuck
    Oct 18, 2012
    3,531
    675
    To implement the exact approach, yes, however, there are typically ways to reduce the logic and implement a complemented function to realize a smaller number of NAND gates than a 1 to 1 AND gate logic implementation.
    In other words, reexamining the NAND gate version can usually reduce the number of gates used when converting to a NAND only implementation.
