I have two transceivers that periodically transmit to each other, roughly 30 times per minute.
They are operating on 433.92mhz and I can successfully hear the transmissions with a scanner set to the frequency they are operating on.
My question is can I intercept the signal with an Arduino or something similar, and at that point decode it, or retransmit it? I know this must be possible but unsure of the equipment needed etc.
I have detailed spec sheets on both transceivers being tested, the modulation is F1D.
