Digital Clock Power Supply Selection
Discussion in 'The Projects Forum' started by Triaca, Dec 16, 2012.
  1. Triaca
    Dec 15, 2012
    7
    I am making DIGITAL CLOCK in which i m using
    1. 6 74LS90(BCD counters)
    2. 6 74LS47(Decoders)
    3. 6 7seg Display(common anode)
    4. 6 74LS08 n 74LS32( AND N OR GATES)
    5. 1 555 timer IC
    according to datasheets of the ICs, i require 5±0.25V n 1-16mA current range for the operation, suggest which power supply would be appropriate?
  2. ScottWang
    Aug 23, 2012
    4,932
    777
    Triaca likes this.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Or you could get a cell phone power supply, depending on where you are getting your clock from. If you looked at the thread I pointed you to I had a fairly cheap crystal oscillator/divider that would provide a 1 Hz source. There are many ways to buy 5V DC wall warts.
    PS: Please stop posting 2 threads on the same subject, you are just creating more work for the moderators, and it will not work.
    Triaca likes this.
